소개
This guide details how to replace the hard drive of a Toshiba Satellite S50-B laptop. You will need a Phillips 0 screwdriver and a plastic opening tool for this replacement.
필요한 것
Locate the 12 screws on the bottom of the device. Unscrew using a Phillips screwdriver, and set screws aside.
Use a plastic opening tool to remove bottom casing.
거의 끝나갑니다!
결론
다른 4명이 해당 안내서를 완성하였습니다.
