주요 콘텐츠로 건너뛰기
Toshiba Satellite S55T-B5335 Cooling Fans Replacement
필요한 것
  1. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 2 단계, 이미지 1/3 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 2 단계, 이미지 2/3 Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 2 단계, 이미지 3/3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 3 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 4 단계, 이미지 1/1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 5 단계, 이미지 1/1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Cooling Fans Replacement, Cooling Fans: 6 단계, 이미지 1/1
    • Remove the two 3.5 mm Phillips #1 screws that hold the cooling fan in place.
  7. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 7 단계, 이미지 1/1
    • Wedge the flat end of the spudger between the connector and its socket.
    • Twist back and forth in order to pry the connector loose from its socket.
    • Although you can pull on the connector wires to remove it from the socket, it is not recommended until the connector is loose to prevent damage to the wires.
  8. Toshiba Satellite S55T-B5335 Cooling Fans Replacement: 8 단계, 이미지 1/1
    • Lift up on the cooling fan to remove it from the laptop.
    • Repeat steps 6-8 for the other cooling fan.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
George Gillespie
회원 가입일: 09/15/16
721 평판
안내서 7개 작성하였습니다
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 1,492
