소개
The keyboard may need to be replaced when a key(s) does not work as intended. This is possibly the most difficult part to replace on this laptop as it requires the most parts to be removed. Please refer to the Keyboard Troubleshooting Guide to determine if your keyboard needs to be replaced.
필요한 것
Remove the twenty-seven 2 mm Phillips #0 screws that secure the keyboard retaining plate.
다른 4명이 해당 안내서를 완성하였습니다.
