주요 콘텐츠로 건너뛰기
Toshiba Satellite S55T-B5335 Touchpad Replacement
필요한 것
  1. Toshiba Satellite S55T-B5335 Touchpad Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Touchpad Replacement: 2 단계, 이미지 1/3 Toshiba Satellite S55T-B5335 Touchpad Replacement: 2 단계, 이미지 2/3 Toshiba Satellite S55T-B5335 Touchpad Replacement: 2 단계, 이미지 3/3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: 3 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Touchpad Replacement: 4 단계, 이미지 1/1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Touchpad Replacement: 5 단계, 이미지 1/1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: 6 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Touchpad Replacement, Touchpad: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using a spudger, lift the black tab that holds the touchpad ribbon cable in place.
    • Using tweezers, pull gently on the purple tab to separate the ribbon cable from the connector.
  7. Toshiba Satellite S55T-B5335 Touchpad Replacement: 7 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Touchpad Replacement: 7 단계, 이미지 2/2
    • Gently push the back side of the touchpad in order to create a gap on the top side of the touchpad.
  8. Toshiba Satellite S55T-B5335 Touchpad Replacement: 8 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Touchpad Replacement: 8 단계, 이미지 2/2
    • Using a plastic opening tool, hold the touchpad up in the position from step 2.
    • While the touchpad is held up, use a spudger to scrape loose the adhesive holding the touchpad to the base.
  9. Toshiba Satellite S55T-B5335 Touchpad Replacement: 9 단계, 이미지 1/1
    • Once the adhesive is separated enough from the touchpad, peel it back and remove it.
결론
George Gillespie
회원 가입일: 09/15/16
721 평판
안내서 7개 작성하였습니다
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 10
전체 시간: 1,485
