주요 콘텐츠로 건너뛰기
Toshiba Satellite S55T-B5335 Wi-Fi Adapter Replacement
필요한 것
  1. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the two 7 mm Phillips #1 screws that hold the battery in place.
  2. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 2 단계, 이미지 1/3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 2 단계, 이미지 2/3 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 2 단계, 이미지 3/3
    • Pull the battery from laptop.
  3. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: 3 단계, 이미지 1/2 Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Bottom Cover: 3 단계, 이미지 2/2
    • Remove the ten 7 mm Phillips #1 screws that secure the back cover.
  4. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 4 단계, 이미지 1/1
    • Wedge the tip of a plastic opening tool between the back cover and the metal frame.
    • Twist the plastic opening tool, while wedged, in order to release the retaining tabs from the frame.
    • Repeat these steps in a circular pattern around the laptop to release all retaining tabs.
  5. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 5 단계, 이미지 1/1
    • Once all retaining tabs are released from the frame, you can pull up on the back cover to remove it.
  6. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement, Wi-Fi Adapter: 6 단계, 이미지 1/1
    • Using the pointed end of the Spudger, gently disconnect the antenna (white and black wires) from the Wi-Fi adapter.
  7. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 7 단계, 이미지 1/1
    • Remove the single 4 mm Phillips #1 screw holding the Wi-Fi adapter in place.
  8. Toshiba Satellite S55T-B5335 Wi-Fi  Adapter Replacement: 8 단계, 이미지 1/1
    • While grabbing the Wi-Fi adapter on both sides, gently pull away from the socket in the direction of the removed screw.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
George Gillespie
회원 가입일: 09/15/16
721 평판
안내서 7개 작성하였습니다
USF Tampa, Team 2-1, Blackwell Fall 2016 USF Tampa, Team 2-1, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S2G1
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
George, do you know where the graphics chip is at on that motherboard?
Any Where - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 1,205
