주요 콘텐츠로 건너뛰기
Toshiba Satellite S55t-A5389 Keyboard Replacement
필요한 것
  1. Toshiba Satellite S55t-A5389 Keyboard Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Flip laptop over so that the bottom is facing upwards.
    • Remove the two 5mm Phillips #0 screws from the bottom of the laptop.
  2. Toshiba Satellite S55t-A5389 Keyboard Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-A5389 Keyboard Replacement: 2 단계, 이미지 2개 중 2개
    • Flip the laptop over and open the display.
    • Insert a plastic opening tool into the gap found between the keyboard and top case.
    • Pry upwards until you hear a click and work your way around the perimeter of the keyboard.
  3. Toshiba Satellite S55t-A5389 Keyboard Replacement: 3 단계, 이미지 3개 중 1개 Toshiba Satellite S55t-A5389 Keyboard Replacement: 3 단계, 이미지 3개 중 2개 Toshiba Satellite S55t-A5389 Keyboard Replacement: 3 단계, 이미지 3개 중 3개
    • Lift the keyboard up, but not all the way since there's a ribbon cable attached underneath.
    • Underneath the keyboard is a ribbon cable that attaches it to the rest of the laptop.
    • Unlock the ribbon cable by lifting up the two small locks on both sides of the connector on the motherboard.
    • Once unlocked, remove the ribbon cable and keyboard from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
William Mazanec
회원 가입일: 01/29/18
1,374 평판
안내서 8개를 작성함
USF Tampa, Team S5-G6, Passmore Spring 2018 USF Tampa, Team S5-G6, Passmore Spring 2018 회원
USFT-PASSMORE-S18S5G6
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 22
전체 시간: 750
