주요 콘텐츠로 건너뛰기
Toshiba Satellite S55t-C5225 Speakers Replacement
필요한 것
  1. Toshiba Satellite S55t-C5225 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Shut down the computer and disconnect all cables
    • Flip the computer over so the bottom is facing up.
  2. Toshiba Satellite S55t-C5225 Speakers Replacement: 2 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the two 7.0 mm Phillips #0 screws that hold the battery in place.
  3. Toshiba Satellite S55t-C5225 Speakers Replacement: 3 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Carefully remove the battery by wedging a plastic opening tool in-between the battery and back cover.
  4. Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: 4 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement, Back Panel: 4 단계, 이미지 2개 중 2개
    • Remove the eleven 7.0 mm Phillips #0 screws that secure the back cover.
  5. Toshiba Satellite S55t-C5225 Speakers Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 5 단계, 이미지 2개 중 2개
    • Wedge the tip of a plastic opening tool between the back cover and metal frame.
    • Twist the plastic tool, while wedged, to release the retaining tabs from the frame.
    • Repeat these steps around the laptop to release all retaining tabs.
  6. Toshiba Satellite S55t-C5225 Speakers Replacement: 6 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Once all retaining tabs are released, pull up on the cover to remove.
  7. Toshiba Satellite S55t-C5225 Speakers Replacement, Speakers: 7 단계, 이미지 1개 중 1개
    • Disconnect the power button strip by flipping up the white plastic clamp that connects it to the motherboard.
    • Pull the ribbon wire out from plastic clamp.
  8. Toshiba Satellite S55t-C5225 Speakers Replacement: 8 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the four 10.0 mm Phillips #0 screws that hold the speakers in place.
  9. Toshiba Satellite S55t-C5225 Speakers Replacement: 9 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • Follow the black wire that connects the speakers to the motherboard.
    • Pull the wire out from its socket to disconnect the speakers from the motherboard.
  10. Toshiba Satellite S55t-C5225 Speakers Replacement: 10 단계, 이미지 2개 중 1개 Toshiba Satellite S55t-C5225 Speakers Replacement: 10 단계, 이미지 2개 중 2개
    • Lift speakers up from their mounted position to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Ali Mortada
회원 가입일: 10/21/19
229 평판
안내서 2개를 작성함
UMass Dartmouth, Team S1-G5, Botvin Fall 2019 UMass Dartmouth, Team S1-G5, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G5
3 회원들
안내서 15개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 36
전체 시간: 1,178
