주요 콘텐츠로 건너뛰기
Toshiba Satellite S75D-A7346 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: 1 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The Battery: 1 단계, 이미지 2/2
    • First we have to take out the battery
    • Pull the switch on the left to the left
    • then hold the switch on the right to the right direction
    • then pull up the bttery from the point inbetween the 2 switches
  2. Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: 2 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, UnScrewing The BackPlate: 2 단계, 이미지 2/2
    • Unscrew the screw located next to the information sticker
    • Then get a screw driver or prier to gently pry the covering plate
  3. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: 3 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking Out The HDD: 3 단계, 이미지 2/2
    • Unscrew the black screws and then pull the black tab to the right
    • Then lift it out and place it somewhere
  4. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: 4 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Taking The HDD Of the Mount: 4 단계, 이미지 2/2
    • Unscrew the silver screws and move the hard drive somewhere else
  5. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Adding The New HDD/SSD To The Mount: 5 단계, 이미지 1/1
    • Screw the silver screws into the screw slots furthest away from the connectors
    • Note: This computer is only compatible with 2.5 inch SATA 3Gbps
  6. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: 6 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Connecting The HDD/SSD: 6 단계, 이미지 2/2
    • Put the Hard Drive in slot (make sure the connectors are on the same side of the connectors
    • Push the Hard Driver into the connector and screw the black screws in
  7. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: 7 단계, 이미지 1/2 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting On The Backplate: 7 단계, 이미지 2/2
    • Put on the backplate and put pressure arround the edges of the blackplate so it stays flat with the case
    • Then screw in the screw next to the information sticker
  8. Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 8 단계, 이미지 1/3 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 8 단계, 이미지 2/3 Toshiba Satellite S75D-A7346 Hard Drive Replacement, Putting In The Battery: 8 단계, 이미지 3/3
    • Place the battery in the slot
    • Then hold the right switch to the right and push the battery in, then release the switch.
    • move the left switch to the right
  9. Toshiba Satellite S75D-A7346 Hard Drive Replacement, You Finished: 9 단계, 이미지 1/1
    • You have know finished the replacement
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Emil Lambert
회원 가입일: 12/16/16
228 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 449
