소개
This installment requires removing a few screws and separating the plastic cover of the laptop allowing you to access the CD/DVD drive. Removing the cover will take a little bit of prying, but make sure to not force anything as you don't want to crack it.
도구
부품
부품은 필요하지 않습니다.
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
With the keyboard removed, locate the marked screws.
Remove the marked 5mm screws using the #1 Phillips Screwdriver.
다른 2명이 해당 안내서를 완성하였습니다.
