주요 콘텐츠로 건너뛰기
Toshiba Satellite U405D-S2902 Display Replacement
필요한 것
  1. Toshiba Satellite U405D-S2902 Display Replacement, Display: 1 단계, 이미지 1/1
    • Use tweezers to remove the small rubber covers over the screws on the top and bottom of the laptop case.
  2. Toshiba Satellite U405D-S2902 Display Replacement: 2 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Display Replacement: 2 단계, 이미지 2/2
    • Use a #1 Phillips screwdriver to remove the 3mm screws located on both sides of the top of the laptop as well as the lower corners.
  3. Toshiba Satellite U405D-S2902 Display Replacement: 3 단계, 이미지 1/3 Toshiba Satellite U405D-S2902 Display Replacement: 3 단계, 이미지 2/3 Toshiba Satellite U405D-S2902 Display Replacement: 3 단계, 이미지 3/3
    • Use a plastic opening tool to separate the front plastic panel from the back side of the top of the laptop.
    • Carefully pull the top away from the back.
  4. Toshiba Satellite U405D-S2902 Display Replacement: 4 단계, 이미지 1/3 Toshiba Satellite U405D-S2902 Display Replacement: 4 단계, 이미지 2/3 Toshiba Satellite U405D-S2902 Display Replacement: 4 단계, 이미지 3/3
    • Turn the laptop around.
    • Remove the webcam/microphone data cable.
  5. Toshiba Satellite U405D-S2902 Display Replacement: 5 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Display Replacement: 5 단계, 이미지 2/2
    • Remove the lower lighting power supply.
    • Remove the signal light power supply and data cable.
  6. Toshiba Satellite U405D-S2902 Display Replacement: 6 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Display Replacement: 6 단계, 이미지 2/2
    • Locate and remove the four 2mm #1 Phillips screws around the sidewalls of the display.
    • After removing the last screw, the screen will be very loose, be sure to keep a hand on it to prevent it from damaging the keyboard.
  7. Toshiba Satellite U405D-S2902 Display Replacement: 7 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Display Replacement: 7 단계, 이미지 2/2
    • Carefully remove the screen from the side brackets.
    • Remove the LCD ribbon connector from the display.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Brandon Kirklen
회원 가입일: 01/11/13
311 평판
안내서 8개 작성하였습니다
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 회원
CPSU-MANESS-W13S7G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 681
