주요 콘텐츠로 건너뛰기
Toshiba Satellite U405D-S2902 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Lay laptop on it's face and remove the two #1 Phillips screws in the back of the black plastic panel with a raised center.
    • The screws can not be removed from the panel, so loosen them until the panel can come off.
    • Carefully lift the panel using the thumb slot on the side closest to you while the battery is pointed out.
  2. Toshiba Satellite U405D-S2902 Hard Drive Replacement: 2 단계, 이미지 1/1
    • After lifting the cover up carefully, slide it to the left to be removed.
  3. Toshiba Satellite U405D-S2902 Hard Drive Replacement: 3 단계, 이미지 1/3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: 3 단계, 이미지 2/3 Toshiba Satellite U405D-S2902 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Place two fingers gently on the hard drive.
    • Slide it back to the left.
    • Lift the drive by the two corner tabs making sure not to touch the metel
    • Do not press down too hard on the top of the drive, or you will damage it. Only use enough pressure to be able to remove it from the SATA connection.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Kirklen
회원 가입일: 01/11/13
311 평판
안내서 8개 작성하였습니다
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 회원
CPSU-MANESS-W13S7G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 492
