소개
The function of the keyboard is to allow you to type on the computer. Sometimes it can break and need to be replaced.
필요한 것
Situate the laptop so that it is open and the display is facing you.
Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
Once the insert is loose, carefully remove it from the device.
다른 2명이 해당 안내서를 완성하였습니다.
