주요 콘텐츠로 건너뛰기
Toshiba Satellite U405D-S2902 Keyboard Replacement
필요한 것
  1. Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 1 단계, 이미지 1/3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 1 단계, 이미지 2/3 Toshiba Satellite U405D-S2902 Keyboard Replacement, Keyboard: 1 단계, 이미지 3/3
    • Situate the laptop so that it is open and the display is facing you.
    • Use the plastic opening tool to pry the black plastic insert upward. The insert can be found at the top of the keyboard.
    • Once the insert is loose, carefully remove it from the device.
  2. Toshiba Satellite U405D-S2902 Keyboard Replacement: 2 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 2 단계, 이미지 2/2
    • Using #1 Phillips Screwdriver, remove both of the 5 mm screws that are located beneath the insert.
  3. Toshiba Satellite U405D-S2902 Keyboard Replacement: 3 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to begin removing the keys off of the device.
    • Once the keys are off, gently remove the keyboard. Be careful of the ribbon cable that still connects the keyboard to motherboard.
  4. Toshiba Satellite U405D-S2902 Keyboard Replacement: 4 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 Keyboard Replacement: 4 단계, 이미지 2/2
    • Lift up the gate on the ZIF socket to release the ribbon.
    • Ease the ribbon connecting the keyboard to the motherboard out of the ZIF socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Kirklen
회원 가입일: 01/11/13
311 평판
안내서 8개 작성하였습니다
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 회원
CPSU-MANESS-W13S7G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 600
