주요 콘텐츠로 건너뛰기
Toshiba Satellite U405D-S2902 RAM Replacement
필요한 것
  1. Toshiba Satellite U405D-S2902 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Lay the device face down with the battery facing away from you. Locate the center panel. It will have two vents in it and three screws on the left side.
    • Loosen the three screws that hold the rear access panel on, using your Phillips #1 Screwdriver.
    • The screws will not actually come out from the panel but will be loose and let the panel come off.
    • Lift the left side of the panel to remove it.
  2. Toshiba Satellite U405D-S2902 RAM Replacement: 2 단계, 이미지 1/1
    • Locate and pull back the two mounting clips on either side of the memory chip.
    • Be sure that when replacing the board, push down gently until the clips snap back in.
  3. Toshiba Satellite U405D-S2902 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite U405D-S2902 RAM Replacement: 3 단계, 이미지 2/2
    • Lift RAM circuit board to about a 45 degree angle and pull gently to the right.
결론
That's it for hardware, the remaining steps will depend on the software platform being run on your laptop.
다른 2명이 해당 안내서를 완성하였습니다.
Brandon Kirklen
회원 가입일: 01/11/13
311 평판
안내서 8개 작성하였습니다
Cal Poly, Team 7-8, Maness Winter 2013 Cal Poly, Team 7-8, Maness Winter 2013 회원
CPSU-MANESS-W13S7G8
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 14
전체 시간: 616
