주요 콘텐츠로 건너뛰기
Toshiba Satellite U925T-S2120 Hard Drive Replacement
필요한 것
  1. Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/2 Toshiba Satellite U925T-S2120 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2/2
    • Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
  2. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 2 단계, 이미지 1/3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: 2 단계, 이미지 2/3 Toshiba Satellite U925T-S2120 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Unscrew nine 5.8 mm screws using a PH1 screwdriver and turning clockwise.
    • Use the same screwdriver to remove the two 6.8 mm screws.
  3. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite U925T-S2120 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Remove the back panel open by inserting the plastic opening tool into the seam of the laptop and pushing downwards. Repeat the motion around the perimeter of the device.
  4. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 4 단계, 이미지 1/1
    • Gently pop out the tab connected to the orange plastic strip.
  5. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Hold back the orange plastic strip with one hand
    • Use a PH1 screwdriver to unscrew the two 3.4 mm screws by turning clockwise.
  6. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Lift the silver flap away from the hard drive.
    • Gently pinch and lift out the hard drive with your thumb and pointer finger.
  7. Toshiba Satellite U925T-S2120 Hard Drive Replacement: 7 단계, 이미지 1/1
    • Completely remove the hard drive from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Terry
회원 가입일: 03/29/17
137 평판
안내서 1개 작성함
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 14
전체 시간: 1,774
