소개
Your hard drive stores and retrieves all memory on your laptop. In this guide you will learn how to remove the hard drive of your Toshiba Satellite U925T-S2120. If your hard drive is broken, you may need to replace it. Prior to beginning this guide you should have all required tools that are listed.
필요한 것
Use tweezers to pinch and pull out and remove the nine rubber gripper pads on the back panel of the laptop. Set aside.
다른 2명이 해당 안내서를 완성하였습니다.
