소개
In this guide you will learn how to remove the heat sink of your Toshiba Satellite U925T-S2120. If your heat sink is clogged or broken, you may need to replace it. Before beginning this guide you should have all required tools that are listed.
필요한 것
Use tweezers to remove the nine rubber grip pads on the back panel of the laptop.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
