주요 콘텐츠로 건너뛰기
Toshiba Satellite U925T-S2120 RAM Replacement
필요한 것
  1. Toshiba Satellite U925T-S2120 RAM Replacement, RAM: 1 단계, 이미지 1/2 Toshiba Satellite U925T-S2120 RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Remove the 9 rubber gripper pads on the back panel of the laptop using tweezers.
  2. Toshiba Satellite U925T-S2120 RAM Replacement: 2 단계, 이미지 1/3 Toshiba Satellite U925T-S2120 RAM Replacement: 2 단계, 이미지 2/3 Toshiba Satellite U925T-S2120 RAM Replacement: 2 단계, 이미지 3/3
    • Unscrew nine 5.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
    • Unscrew two 6.8 mm screws by turning a PH1 screwdriver clockwise after inserting it into the screw.
  3. Toshiba Satellite U925T-S2120 RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite U925T-S2120 RAM Replacement: 3 단계, 이미지 2/2
    • Take off the back panel open by sticking the plastic opening tool into the seam of the laptop, and pushing the opening tool downwards.
  4. Toshiba Satellite U925T-S2120 RAM Replacement: 4 단계, 이미지 1/2 Toshiba Satellite U925T-S2120 RAM Replacement: 4 단계, 이미지 2/2
    • Gently pinch the RAM with your thumb and pointer finger.
    • Pull the RAM out of the logic board with gentle force.
    • Try to keep the RAM parallel as you pull it out, so that the RAM does not chip.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Andrew Honderich
회원 가입일: 03/29/17
364 평판
안내서 3개 작성하였습니다
Baylor, Team S5-G5, Williams Spring 2017 Baylor, Team S5-G5, Williams Spring 2017 회원
BU-WILLIAMS-S17S5G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 7
전체 시간: 546
