주요 콘텐츠로 건너뛰기
Toshiba Satellite c650d Hard Drive Replacement
필요한 것
  1. Toshiba Satellite c650d Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d Hard Drive Replacement: 2 단계, 이미지 1/1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d Hard Drive Replacement: 3 단계, 이미지 1/2 Toshiba Satellite c650d Hard Drive Replacement: 3 단계, 이미지 2/2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/2 Toshiba Satellite c650d Hard Drive Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove the one 5.0mm Philips #0 screw that holds down the panel covering the hard drive.
  5. Toshiba Satellite c650d Hard Drive Replacement: 5 단계, 이미지 1/1
    • Pull off the panel.
  6. Toshiba Satellite c650d Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the one 3.0mm Philip's #0 screw holding the hard drive in place.
  7. Toshiba Satellite c650d Hard Drive Replacement: 7 단계, 이미지 1/1
    • Slide the hard drive out.
결론
Brenna Callahan
회원 가입일: 10/21/15
868 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 16
전체 시간: 2,676
