주요 콘텐츠로 건너뛰기
Toshiba Satellite c650d RAM Replacement
필요한 것
  1. Toshiba Satellite c650d RAM Replacement, Battery: 1 단계, 이미지 1/1
    • Unplug the laptop and turn it off.
    • Flip the laptop upside down.
    • Locate the battery on the underside of the laptop.
  2. Toshiba Satellite c650d RAM Replacement: 2 단계, 이미지 1/1
    • Push the two latches away from the battery.
  3. Toshiba Satellite c650d RAM Replacement: 3 단계, 이미지 1/2 Toshiba Satellite c650d RAM Replacement: 3 단계, 이미지 2/2
    • Slide the battery away from the laptop.
    • Locate the serial number on the battery to order a replacement.
  4. Toshiba Satellite c650d RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Remove the one 5.5mm Philips #0 screw that holds in the central panel.
  5. Toshiba Satellite c650d RAM Replacement: 5 단계, 이미지 1/1
    • Pull the back panel off.
  6. Toshiba Satellite c650d RAM Replacement: 6 단계, 이미지 1/1
    • Remove the RAM.
    • Carefully undo the clips on either side of the top RAM.
    • Remove the chip by pulling it out of its slot.
    • Repeat until you have removed the chip that you want to replace.
    • This laptop has only two slots for RAM, and both are filled. Plan accordingly if your goal is to increase RAM.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Brenna Callahan
회원 가입일: 10/21/15
868 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 UMass Dartmouth, Team 5-2, Gulbrandsen Fall 2015 회원
UMASSD-GULBRANDSEN-F15S5G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 652
