주요 콘텐츠로 건너뛰기
Toshiba Satellite e205 Keyboard Replacement
필요한 것
  1. Toshiba Satellite e205 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite e205 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Keyboard Replacement, Keyboard: 2 단계, 이미지 1/1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Keyboard Replacement: 3 단계, 이미지 1/1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Keyboard Replacement: 4 단계, 이미지 1/1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 06/19/12
4,920 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 25개 작성하였습니다
댓글 2개
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - 답글
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 635
