소개
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
필요한 것
With the battery away from you, slide the locking clips out.
Slide the battery away from you.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 2개
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - 답글
