주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The keyboard needs to be removed to access everything (hard drive, optical drive, RAM, motherboard).
부품
지정된 부품이 없습니다.
  1. With the battery away from you, slide the locking clips out. The left clip stays, the right clip is spring loaded.
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Use a spudger to carefully pry up the keyboard screw cover.
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Remove the two screws securing the keyboard to the chassis.
    • Remove the two screws securing the keyboard to the chassis.
  4. Carefully tilt the keyboard towards you and release the ribbon cables.
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 2012년 06월 19일
4,689 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 18개 작성하였습니다
What is the brass colored ribbon for? Mine is broken will it effect funconality , if so how do i fix it
Kathleen T - 답글
If I remember correctly, this keyboard is backlit. Most likely the copper cable is for the backlit power. A new keyboard would need to be purchased to fix it.
Tyler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 515
