주요 콘텐츠로 건너뛰기
Toshiba Satellite e205 Optical Drive Replacement
필요한 것
  1. Toshiba Satellite e205 Optical Drive Replacement, Battery: 1 단계, 이미지 1/2 Toshiba Satellite e205 Optical Drive Replacement, Battery: 1 단계, 이미지 2/2
    • With the battery away from you, slide the locking clips out.
    • The left clip stays, the right clip is spring loaded.
    • Slide the battery away from you.
  2. Toshiba Satellite e205 Optical Drive Replacement, Keyboard: 2 단계, 이미지 1/1
    • Use a spudger to carefully pry up the keyboard screw cover.
  3. Toshiba Satellite e205 Optical Drive Replacement: 3 단계, 이미지 1/1
    • Remove the two screws securing the keyboard to the chassis.
  4. Toshiba Satellite e205 Optical Drive Replacement: 4 단계, 이미지 1/1
    • Carefully tilt the keyboard towards you and release the ribbon cables.
    • Use a spudger if needed to release the latch. The latch slides out.
    • The keyboard is now free and can be set aside.
  5. Toshiba Satellite e205 Optical Drive Replacement, Bottom Cover: 5 단계, 이미지 1/1
    • Remove the five black screws
    • Remove the one silver screw
  6. Toshiba Satellite e205 Optical Drive Replacement: 6 단계, 이미지 1/1
    • Flip the laptop over so the bottom is facing up.
    • Using a spudger, remove the seven rubber inserts.
    • The feet only go in one location on the bottom of the laptop, so save yourself some time and track where they go.
  7. Toshiba Satellite e205 Optical Drive Replacement: 7 단계, 이미지 1/1
    • Remove the six silver screws.
    • Remove the one black screw.
  8. Toshiba Satellite e205 Optical Drive Replacement: 8 단계, 이미지 1/2 Toshiba Satellite e205 Optical Drive Replacement: 8 단계, 이미지 2/2
    • Stand the laptop up on end.
    • Remove the two rubber inserts from the back of the laptop. One insert is on each side of the laptop.
  9. Toshiba Satellite e205 Optical Drive Replacement: 9 단계, 이미지 1/2 Toshiba Satellite e205 Optical Drive Replacement: 9 단계, 이미지 2/2
    • Remove the two screews.
  10. Toshiba Satellite e205 Optical Drive Replacement: 10 단계, 이미지 1/1
    • Carefully work a spudger in the crack at the back of the laptop and separate the small rubberized section from the bottom of the laptop.
  11. Toshiba Satellite e205 Optical Drive Replacement: 11 단계, 이미지 1/1
    • Remove the four screws.
    • Disconnect the black wireless antenna lead.
  12. Toshiba Satellite e205 Optical Drive Replacement: 12 단계, 이미지 1/1
    • The bottom of the laptop is now ready to lift off.
    • Carefully work a spudger around the seam of the laptop separating the bottom from the rest of the laptop.
    • There is a data connection at the front of the laptop that needs to be disconnected.
    • Use a spuder to carefully disconnect the wire from the motherboard. Once this is free the bottom will come off.
  13. Toshiba Satellite e205 Optical Drive Replacement, Optical Drive: 13 단계, 이미지 1/2 Toshiba Satellite e205 Optical Drive Replacement, Optical Drive: 13 단계, 이미지 2/2
    • Locate optical drive
    • Remove the three screws securing the optical drive.
    • Slide the optical drive away from the motherboard, and carefully lift up.
결론
Tyler
회원 가입일: 06/19/12
4,920 평판
안내서 16개 작성하였습니다
TechForce TechForce 회원
Business
2 회원들
안내서 25개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 439
