소개
If you need to replace the disk drive, follow this guide. The disk drive can be accessed from the bottom of the computer. To replace this part, you will need a Phillips 0 screw driver and a plastic opening tool.
필요한 것
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
거의 끝나갑니다!
결론
