소개
If you need to replace the hard drive, follow this guide. The hard drive is located underneath the computer. To replace this part, you will need a Phillips 00 screw driver and a plastic prying tool. This process should not require any excessive force.
필요한 것
Remove the battery by sliding the tabs to the left.
Use the spudger to lift the battery out.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
