주요 콘텐츠로 건너뛰기
Toshiba Satellite p875 s7200 RAM Stick Replacement
필요한 것
  1. Toshiba Satellite p875 s7200 RAM Stick Replacement, RAM Stick: 1 단계, 이미지 1/1
    • Remove the battery by sliding the tabs to the left.
    • Use the spudger to lift the battery out.
  2. Toshiba Satellite p875 s7200 RAM Stick Replacement: 2 단계, 이미지 1/1
    • Use the Phillips head screw driver to remove the screw holding the back plate on.
    • Use the spudger to remove the back plate.
  3. Toshiba Satellite p875 s7200 RAM Stick Replacement: 3 단계, 이미지 1/1
    • Unlock the RAM by lightly pushing the two metallic holding arms away from the RAM stick.
    • The holding arms can be pressed together or one at a time.
    • The RAM sticks one of its edges slightly away away from the computer when unlocked.
  4. Toshiba Satellite p875 s7200 RAM Stick Replacement: 4 단계, 이미지 1/1
    • Grab the RAM stick by the protruding edge.
    • Pull the RAM stick towards the right to remove.
결론
Danny Amado
회원 가입일: 10/29/18
823 평판
안내서 5개 작성하였습니다
Baylor, Team S1-G3, Williams Fall 2018 Baylor, Team S1-G3, Williams Fall 2018 회원
BU-WILLIAMS-F18S1G3
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 7
전체 시간: 353
