주요 콘텐츠로 건너뛰기
Toshiba T2400CS Hard drive Replacement
필요한 것
  1. Toshiba T2400CS Hard drive Replacement, Removing the battery: 1 단계, 이미지 1개 중 1개
    • 1.A) Slide the little plastic cover forward
    • 1.B) Push the button underneath the cover
    • 1.C) Slide the battery out
  2. Toshiba T2400CS Hard drive Replacement, Undo the screws on the bottom of the laptop: 2 단계, 이미지 1개 중 1개
    • The bottom of the laptop has 6 visible screws and the 7th one is hidden under the battery
  3. Toshiba T2400CS Hard drive Replacement, Undo the screws on the back of the laptop: 3 단계, 이미지 1개 중 1개
    • The back of the laptop has 2 screws.
  4. Toshiba T2400CS Hard drive Replacement, Removing the palmrest: 4 단계, 이미지 1개 중 1개
    • 4.A) Gently lift the bottom of the palmrest up
    • 4.B) Carefully pull the palmrest toward yourself, dislodging it from the top half of the case
  5. Toshiba T2400CS Hard drive Replacement, Removing the keyboard: 5 단계, 이미지 1개 중 1개
    • 5.A) Gently release the ribbon cable tabs and pull the ribbon cable out
    • 5.B) Raise the bottom of the keyboard and pull it out of the case
  6. Toshiba T2400CS Hard drive Replacement, Release the top part of the case: 6 단계, 이미지 1개 중 1개
    • 6.A) Undo the screw
    • 6.B) Gently use a flat tool to pull back the plastic tabs, releasing the sides
  7. Toshiba T2400CS Hard drive Replacement, Remove the top part of the case: 7 단계, 이미지 1개 중 1개
    • 7.A) Carefully pull the bottom of the top part up
    • 7.B) Gently pull up and toward yourself to remove the part
  8. Toshiba T2400CS Hard drive Replacement, Prepare to remove the daughter board: 8 단계, 이미지 2개 중 1개 Toshiba T2400CS Hard drive Replacement, Prepare to remove the daughter board: 8 단계, 이미지 2개 중 2개
    • 8.A) Undo all the highlighted screws
    • 8.B) Carefully release the CMOS battery cable from the board
    • 8.C) (optional) Lift up and remove the bottom right latch piece
  9. Toshiba T2400CS Hard drive Replacement, Remove the daughter board: 9 단계, 이미지 1개 중 1개
    • Carefully but firmly lift up the top part of the daughter board by the corners from it's connector and lift the entire board out of the case.
  10. Toshiba T2400CS Hard drive Replacement, Remove the hard drive: 10 단계, 이미지 1개 중 1개
    • 10.A) Undo the screws holding the hard drive bracket in place
    • 10.B) Slide the hard drive toward yourself to release it from the connector
  11. Toshiba T2400CS Hard drive Replacement: 11 단계, 이미지 2개 중 1개 Toshiba T2400CS Hard drive Replacement: 11 단계, 이미지 2개 중 2개
    • Undo the screws on each side of the bracket and your hard drive is free!
    • To reassemble the computer with a new hard drive, repeat the steps backwards.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
slydoge
회원 가입일: 02/19/20
253 평판
안내서 1개를 작성함
1가이드 댓글
Thanks mom very cool
Bunneh 4444 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 12
전체 시간: 698
