주요 콘텐츠로 건너뛰기
Toshiba TDP-XP2 Fan Replacement
필요한 것
  1. Toshiba TDP-XP2 Fan Replacement, Fan: 1 단계, 이미지 1/3 Toshiba TDP-XP2 Fan Replacement, Fan: 1 단계, 이미지 2/3 Toshiba TDP-XP2 Fan Replacement, Fan: 1 단계, 이미지 3/3
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fan Replacement: 2 단계, 이미지 1/2 Toshiba TDP-XP2 Fan Replacement: 2 단계, 이미지 2/2
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fan Replacement: 3 단계, 이미지 1/3 Toshiba TDP-XP2 Fan Replacement: 3 단계, 이미지 2/3 Toshiba TDP-XP2 Fan Replacement: 3 단계, 이미지 3/3
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fan Replacement: 4 단계, 이미지 1/1
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fan Replacement: 5 단계, 이미지 1/3 Toshiba TDP-XP2 Fan Replacement: 5 단계, 이미지 2/3 Toshiba TDP-XP2 Fan Replacement: 5 단계, 이미지 3/3
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fan Replacement: 6 단계, 이미지 1/2 Toshiba TDP-XP2 Fan Replacement: 6 단계, 이미지 2/2
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fan Replacement: 7 단계, 이미지 1/3 Toshiba TDP-XP2 Fan Replacement: 7 단계, 이미지 2/3 Toshiba TDP-XP2 Fan Replacement: 7 단계, 이미지 3/3
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fan Replacement: 8 단계, 이미지 1/1
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fan Replacement: 9 단계, 이미지 1/1
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fan Replacement: 10 단계, 이미지 1/2 Toshiba TDP-XP2 Fan Replacement: 10 단계, 이미지 2/2
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fan Replacement: 11 단계, 이미지 1/1
    • Remove the power board to reveal the bottom two screws to the fan.
    • Unscrew the fan and replace it with an equivalent one.
결론
Bryan Underwood
회원 가입일: 04/02/18
697 평판
안내서 5개 작성하였습니다
University of Memphis, Team S1-G3, Kim Spring 2018 University of Memphis, Team S1-G3, Kim Spring 2018 회원
UM-KIM-S18S1G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 269
