주요 콘텐츠로 건너뛰기
Toshiba TECRA R940 Back Panel Replacement
필요한 것
  1. Toshiba TECRA R940 Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Slide lock 1, located on the right side, to the unlocked position.
  2. Toshiba TECRA R940 Back Panel Replacement: 2 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement: 2 단계, 이미지 2개 중 2개
    • While holding lock 2 (left side) in the unlocked position, pull out the battery pack.
    • It is not necessary to hold open lock 2 for re-installation.
  3. Toshiba TECRA R940 Back Panel Replacement, Back Panel: 3 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement, Back Panel: 3 단계, 이미지 2개 중 2개
    • Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
    • The screw will not come apart from the panel.
    • Use a plastic opening tool to pry off the access panel.
  4. Toshiba TECRA R940 Back Panel Replacement: 4 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the 11 mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  5. Toshiba TECRA R940 Back Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Remove twelve 5.5 mm screws from the main back cover using a Phillips #0 screwdriver.
    • Remove three 11 mm screws from main back cover and mini access panel using a Phillips #0 screwdriver.
    • Remove two 9.5 mm screws from the main back cover using a Phillips #0 screwdriver.
  6. Toshiba TECRA R940 Back Panel Replacement: 6 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the hard drive out of the access panel.
    • Disconnect the SATA connector from the hard drive by pulling straight out.
  7. Toshiba TECRA R940 Back Panel Replacement: 7 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Back Panel Replacement: 7 단계, 이미지 2개 중 2개
    • Insert the plastic opening tool into the edge of the laptop and pry off the back cover.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Holly Strauch
회원 가입일: 09/23/18
430 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 12
전체 시간: 1,142
