소개
The CPU cooling fan is simple to replace and may need to be removed if the motherboard is replaced.
필요한 것
Unscrew the single screw on the RAM access panel using a Phillips #0 screwdriver.
Use a plastic opening tool to pry off the access panel.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
