주요 콘텐츠로 건너뛰기
Toshiba TECRA R940 Hard Drive Replacement
필요한 것
  1. Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Loosen the screw holding the back panel for RAM in place using a Phillips #0 screwdriver. Once loosened, lift the panel up and set it aside.
    • The screw holding the panel in place should not come completely out. If it does, do not be alarmed as it will still screw back in.
  2. Toshiba TECRA R940 Hard Drive Replacement: 2 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Hard Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 11mm screw from the right side of the hard drive access panel using a Phillips #0 screwdriver.
    • Remove the 3.5 mm screw from the left side of the access panel using a Phillips #0 screwdriver.
    • Use a plastic opening tool to pry off the access panel from the bottom.
  3. Toshiba TECRA R940 Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 Toshiba TECRA R940 Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift the hard drive from the left side and disconnect the SATA connector from the right side. Completely remove the hard drive.
결론
작성자
3다른 기여자 명과 함께
Holly Strauch
회원 가입일: 09/23/18
430 평판
안내서 4개를 작성함
댓글 한 개
I cannot lift up the “back cover” (step 1). I’ve twirled the screw left for minutes and tried to lift up the panel using a small flathead screwdriver and it will not lift up. HELP!
Remy Secor - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 1,144
