주요 콘텐츠로 건너뛰기
Toshiba TY-LP 200 Belt Replacement
필요한 것
  1. Toshiba TY-LP 200 Belt Replacement, Belt: 1 단계, 이미지 1/2 Toshiba TY-LP 200 Belt Replacement, Belt: 1 단계, 이미지 2/2
    • Unplug the turntable and remove the dust cover by lifting the lid horizontally.
  2. Toshiba TY-LP 200 Belt Replacement: 2 단계, 이미지 1/2 Toshiba TY-LP 200 Belt Replacement: 2 단계, 이미지 2/2
    • Locate the C-clip at the center base of the platter and remove it with a flathead screwdriver.
  3. Toshiba TY-LP 200 Belt Replacement: 3 단계, 이미지 1/2 Toshiba TY-LP 200 Belt Replacement: 3 단계, 이미지 2/2
    • Once removed, very gently lift the platter straight up and off the device.
    • Flip the platter upside down.
  4. Toshiba TY-LP 200 Belt Replacement: 4 단계, 이미지 1/3 Toshiba TY-LP 200 Belt Replacement: 4 단계, 이미지 2/3 Toshiba TY-LP 200 Belt Replacement: 4 단계, 이미지 3/3
    • Place the new belt around the center ring of the upside-down platter.
    • After placing the new belt, stretch the belt towards one of the indented areas on the back of the platter.
  5. Toshiba TY-LP 200 Belt Replacement: 5 단계, 이미지 1/1
    • Locate the spool drive that is surrounded by three screws.
  6. Toshiba TY-LP 200 Belt Replacement: 6 단계, 이미지 1/1
    • Once you have located the spool drive, place the stretched belt over it, and gently put back the platter into its original form, as shown in step 2.
    • If this step is done correctly, once the platter is spun, it will stop by itself.
  7. Toshiba TY-LP 200 Belt Replacement: 7 단계, 이미지 1/2 Toshiba TY-LP 200 Belt Replacement: 7 단계, 이미지 2/2
    • Place the C-type back into its original place and, with your finger, attach it onto the spindle.
    • Reinstall the dust cover by placing it on the snaps and applying force downwards.
결론
You now have a fixed and working record player.
Andrew
회원 가입일: 05/14/20
145 평판
안내서 1개 작성함
York University, Team S1-G28, O'Regan Summer 2020 York University, Team S1-G28, O'Regan Summer 2020 회원
YORK-O'REGAN-SU20S1G28
1 회원
안내서 1개 작성하였습니다
댓글 3개
Thank you so much for this! Incredibly helpful!!!
Judi Dell'Anno - 답글
Replacement belt size?
lyam_pa - 답글
Along with this fix, I tried to clean a bit of dust and grime that's accumulated throughout the 3 decades. Some is not coming off with vacuuming or dry-wiping. Any advice on how to clean the unit up before reassembly? Mine is a gold Marantz with similar design and some of its parts are not as smooth as they should be. Thanks so much
Edie K - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,208
