주요 콘텐츠로 건너뛰기
Toshiba Tecra 8200 Hard Drive Replacement
필요한 것
  1. Toshiba Tecra 8200 Hard Drive Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the device and unplug the power cord.
    • To remove the battery, flip the device, so that the bottom is facing upward.
  2. Toshiba Tecra 8200 Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Toshiba Tecra 8200 Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Toshiba Tecra 8200 Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Slide the battery to the right side until you hear a click.
    • Carefully remove the battery from its compartment.
  3. Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 1개 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 2개 Toshiba Tecra 8200 Hard Drive Replacement, Hard Drive: 3 단계, 이미지 3개 중 3개
    • Locate the hard drive panel.
    • Remove the single screw labeled F4 by using a Philips size #00 screwdriver.
    • Save the screw, as it will be needed for reassembly.
    • Remove the panel, exposing the hard drive.
  4. Toshiba Tecra 8200 Hard Drive Replacement: 4 단계, 이미지 2개 중 1개 Toshiba Tecra 8200 Hard Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Pull the tab to remove the hard drive.
    • Insert the new hard drive by pushing it into the compartment, leaving the new "pull" tab exposed.
  5. Toshiba Tecra 8200 Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 Toshiba Tecra 8200 Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Tuck the "pull" tab back into the hard drive compartment.
    • Replace the panel.
    • Replace the single F4 screw.
  6. Toshiba Tecra 8200 Hard Drive Replacement: 6 단계, 이미지 3개 중 1개 Toshiba Tecra 8200 Hard Drive Replacement: 6 단계, 이미지 3개 중 2개 Toshiba Tecra 8200 Hard Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Identify the connector pins on the battery.
    • Line up the connector pins on the battery with the connector pins on the computer and push inward to reconnect the battery.
    • Slide the exterior panel towards the center of the computer to lock the battery in place.
결승점
작성자
7다른 기여자 명과 함께
Sally
회원 가입일: 02/17/15
306 평판
안내서 3개를 작성함
Ohio State, Team 1-3, Buehl Winter 2015 Ohio State, Team 1-3, Buehl Winter 2015 회원
OSU-BUEHL-W15S1G3
3 회원들
안내서 9개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 27
전체 시간: 2,352
