소개
RAM, or random access memory, is short-term storage for your Toshiba Tecra Z50-A. RAM is used by your processor for immediate use as needed, unlike long-term like files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The Toshiba Tecra A50–A laptop comes standard with 8GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
필요한 것
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
