소개
Is your speaker volume too low or not there at all? If so you’ll need to replace your faulty speakers with new ones. This guide will show you the steps you need to know.
필요한 것
Turn off the laptop.
Flip the laptop over so the bottom is facing upwards and the hinges are closest to you.
Remove the fifteen 5 mm screws from the back panel using a Phillips #0 screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
