주요 콘텐츠로 건너뛰기
Toshiba Thrive 4G Battery Replacement
필요한 것
  1. Toshiba Thrive 4G Battery Replacement, Removing Outer Shell: 1 단계, 이미지 1/1
    • To remove the outer casing, wedge the pry tool in between the front and back panel, and pull them apart.
  2. Toshiba Thrive 4G Battery Replacement, Unlock the Battery: 2 단계, 이미지 1/1
    • Locate the lock switch, at the top left corner of the device, and adjust to the unlocked position. (from left to right)
  3. Toshiba Thrive 4G Battery Replacement, Take Battery Out: 3 단계, 이미지 1/2 Toshiba Thrive 4G Battery Replacement, Take Battery Out: 3 단계, 이미지 2/2
    • Use your fingers to push the release switch, which is located at the top right corner of the device to the right.
    • While pushing the release switch to the right, use your other hand to pull the battery away from the inner casing.
  4. Toshiba Thrive 4G Battery Replacement, Replace Battery: 4 단계, 이미지 1/1
    • To replace the battery, take your replacement piece and flip it upside down, revealing the warnings and specifications of that specific battery.
    • Locate the crevice at the bottom of the battery, which has black openings in it.
    • Line up the black openings with the golden prongs located on the inner casing, and slide the battery into place.
    • Move the lock/unlock switch to the locked position
결론
Courtney Campbell
회원 가입일: 10/22/14
301 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-1, Shastany Fall 2014 UMass Dartmouth, Team 1-1, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 235
