주요 콘텐츠로 건너뛰기
Toshiba Thrive Charging Port Replacement
필요한 것
  1. Toshiba Thrive Charging Port Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Charging Port Replacement: 2 단계, 이미지 1/2 Toshiba Thrive Charging Port Replacement: 2 단계, 이미지 2/2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Charging Port Replacement: 3 단계, 이미지 1/1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Charging Port Replacement: 4 단계, 이미지 1/3 Toshiba Thrive Charging Port Replacement: 4 단계, 이미지 2/3 Toshiba Thrive Charging Port Replacement: 4 단계, 이미지 3/3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Charging Port Replacement, Midframe: 5 단계, 이미지 1/2 Toshiba Thrive Charging Port Replacement, Midframe: 5 단계, 이미지 2/2
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Charging Port Replacement: 6 단계, 이미지 1/3 Toshiba Thrive Charging Port Replacement: 6 단계, 이미지 2/3 Toshiba Thrive Charging Port Replacement: 6 단계, 이미지 3/3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Charging Port Replacement: 7 단계, 이미지 1/3 Toshiba Thrive Charging Port Replacement: 7 단계, 이미지 2/3 Toshiba Thrive Charging Port Replacement: 7 단계, 이미지 3/3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Charging Port Replacement: 8 단계, 이미지 1/2 Toshiba Thrive Charging Port Replacement: 8 단계, 이미지 2/2
    • Carefully open the device like a book and lay the two halves beside each other.
  9. Toshiba Thrive Charging Port Replacement, Charging Port: 9 단계, 이미지 1/3 Toshiba Thrive Charging Port Replacement, Charging Port: 9 단계, 이미지 2/3 Toshiba Thrive Charging Port Replacement, Charging Port: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the two screws holding the charging port in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, lift up the charging port's protective covering
  10. Toshiba Thrive Charging Port Replacement: 10 단계, 이미지 1/3 Toshiba Thrive Charging Port Replacement: 10 단계, 이미지 2/3 Toshiba Thrive Charging Port Replacement: 10 단계, 이미지 3/3
    • Use the tweezers to pull out the connector connecting the charging port to the motherboard.
    • Using the tweezers again, gently lift up the charging port from your Thrive.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Kason
회원 가입일: 09/22/14
1,120 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 회원
USFT-BROWN-F14S10G1
3 회원들
안내서 12개 작성하였습니다
댓글 한 개
I added "better pictures" flag because i was having trouble following the last step cause i couldnt see anything.
Sun Fai Lau - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 4,075
