주요 콘텐츠로 건너뛰기
Toshiba Thrive Front Camera Replacement
필요한 것
  1. Toshiba Thrive Front Camera Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Front Camera Replacement: 2 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement: 2 단계, 이미지 2/2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Front Camera Replacement: 3 단계, 이미지 1/1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 1/3 Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 2/3 Toshiba Thrive Front Camera Replacement: 4 단계, 이미지 3/3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Front Camera Replacement, Midframe: 5 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement, Midframe: 5 단계, 이미지 2/2
    • Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 1/3 Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 2/3 Toshiba Thrive Front Camera Replacement: 6 단계, 이미지 3/3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 1/3 Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 2/3 Toshiba Thrive Front Camera Replacement: 7 단계, 이미지 3/3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Front Camera Replacement: 8 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement: 8 단계, 이미지 2/2
    • Carefully open the device like a book and lay the two halves beside each other.
  9. Toshiba Thrive Front Camera Replacement, Front Camera: 9 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement, Front Camera: 9 단계, 이미지 2/2
    • Separate the two halves of your Thrive
    • Using a Phillips screwdriver, remove the six screws holding the LCD in place. These screws are 3mm in length and require a PH0 screwdriver.
  10. Toshiba Thrive Front Camera Replacement: 10 단계, 이미지 1/1
    • With a spudger, disconnect the cable connecting the camera to the motherboard.
  11. Toshiba Thrive Front Camera Replacement: 11 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement: 11 단계, 이미지 2/2
    • Lift up the LCD from the screen and place it on the side
  12. Toshiba Thrive Front Camera Replacement: 12 단계, 이미지 1/2 Toshiba Thrive Front Camera Replacement: 12 단계, 이미지 2/2
    • Remove the one screw holding the camera in place. The screw is 3mm in length and requires a PH0 screwdriver.
    • Lift up the camera from the screen.
결론
Kason
회원 가입일: 09/22/14
1,120 평판
안내서 5개 작성하였습니다
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 회원
USFT-BROWN-F14S10G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 378
