소개
This guide will show you how to open your Thrive. Something that must be done for most repairs.
필요한 것
Make sure the lock switch for the back cover is unlocked.
The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
Start by using a screwdriver to remove the 12 screws holding on the back cover. The screws are 5mm in length and require a PH0 screwdriver.
All of these screws are identical so don't worry about getting them mixed up.
다른 3명이 해당 안내서를 완성하였습니다.
