주요 콘텐츠로 건너뛰기
Toshiba Thrive Speakers Replacement
필요한 것
  1. Toshiba Thrive Speakers Replacement, Back Cover: 1 단계, 이미지 1/1
    • Make sure the lock switch for the back cover is unlocked.
    • The cover is unlocked when the switch is slid in the direction of the 'unlock' icon.
  2. Toshiba Thrive Speakers Replacement: 2 단계, 이미지 1/2 Toshiba Thrive Speakers Replacement: 2 단계, 이미지 2/2
    • Remove back cover by prying away from the Thrive.
    • The easiest place to pry from is one of the two speakers.
  3. Toshiba Thrive Speakers Replacement: 3 단계, 이미지 1/1
    • To remove the battery, make sure the lock switch is in the unlocked position.
    • The battery is unlocked when the switch is slid to the unlocked position.
  4. Toshiba Thrive Speakers Replacement: 4 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 4 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 4 단계, 이미지 3/3
    • Slide the battery switch release to the right.
    • While holding the switch in place, lift up the battery.
  5. Toshiba Thrive Speakers Replacement, Speakers: 5 단계, 이미지 1/2 Toshiba Thrive Speakers Replacement, Speakers: 5 단계, 이미지 2/2
    • Start by using a PH0 phillips head screwdriver to remove the 12 screws holding on the back cover
    • All of these screws are identical so don't worry about getting them mixed up.
  6. Toshiba Thrive Speakers Replacement: 6 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 6 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 6 단계, 이미지 3/3
    • Start to gently pry the back of the device off, while leaving it loosely in place.
    • Be careful not to tear or damage the cables when removing the back.
  7. Toshiba Thrive Speakers Replacement: 7 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 7 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 7 단계, 이미지 3/3
    • Once the back of the case is off, disconnect the wires by gently pulling on the plastic tabs as shown.
  8. Toshiba Thrive Speakers Replacement: 8 단계, 이미지 1/2 Toshiba Thrive Speakers Replacement: 8 단계, 이미지 2/2
    • carefully open the device like a book and lay the two halves beside each other.
    • put the screen assembly in a safe place as you complete the rest of the guide.
  9. Toshiba Thrive Speakers Replacement: 9 단계, 이미지 1/2 Toshiba Thrive Speakers Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to open the latch holding the last wire to the back of the device.
  10. Toshiba Thrive Speakers Replacement: 10 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 10 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 10 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the two screws holding the speakers in place. The screws are 3mm in length and require a PH0 screwdriver.
    • Using a pair of tweezers, remove the speaker.
  11. Toshiba Thrive Speakers Replacement: 11 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 11 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 11 단계, 이미지 3/3
    • Use the tweezers to help you remove the speaker wire from the clips holding them in place.
    • After removal place the left speaker on the side.
  12. Toshiba Thrive Speakers Replacement: 12 단계, 이미지 1/3 Toshiba Thrive Speakers Replacement: 12 단계, 이미지 2/3 Toshiba Thrive Speakers Replacement: 12 단계, 이미지 3/3
    • Use the tweezers again to help you remove the right speaker from its position.
    • Use a plastic opening tool to pull the connector connecting the speaker to the motherboard out of its port.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ivan Williams
회원 가입일: 09/22/14
133 평판
안내서 1개 작성함
USF Tampa, Team 10-1, Brown Fall 2014 USF Tampa, Team 10-1, Brown Fall 2014 회원
USFT-BROWN-F14S10G1
3 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 365
