주요 콘텐츠로 건너뛰기
TotalPond Pond Pump Impeller Rubber Stop Replacement
  1. TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 1 단계, 이미지 1/3 TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 1 단계, 이미지 2/3 TotalPond Pond Pump Impeller Rubber Stop Replacement, Impeller Rubber Stop: 1 단계, 이미지 3/3
    • Hold the inlet screen and rotate it counterclockwise to unscrew it. It is helpful to remove the inlet screen so that it is not damaged during the replacement process.
  2. TotalPond Pond Pump Impeller Rubber Stop Replacement: 2 단계, 이미지 1/3 TotalPond Pond Pump Impeller Rubber Stop Replacement: 2 단계, 이미지 2/3 TotalPond Pond Pump Impeller Rubber Stop Replacement: 2 단계, 이미지 3/3
    • Firmly hold the pump block with one hand and the impeller housing with the other hand. Rotate impeller housing counterclockwise until it is released.
  3. TotalPond Pond Pump Impeller Rubber Stop Replacement: 3 단계, 이미지 1/2 TotalPond Pond Pump Impeller Rubber Stop Replacement: 3 단계, 이미지 2/2
    • Remove the rubber stop that is attached to the tube that runs through the middle of the impeller.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicole Santana
회원 가입일: 01/13/15
597 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-6, Hickman Winter 2015 USF Tampa, Team 3-6, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G6
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 618
