소개
This guide will provide you with detailed instructions regarding the replacement of a towel bar in your bathroom. The towel bar may need replacing if it is beginning to rust or becoming loose. The rust could potentially get on your towels as well as make the towel bar more difficult to remove. Also, if the towel bar is becoming loose, it may be at risk of breaking soon. Replacing the towel bar before it becomes rusted or loose, allows for a fresh, aesthetic-looking bathroom as well as a clean, safe surface for your towels.
필요한 것
Measure the length of your current towel bar to make sure that your replacement towel bar is the correct size and will fit onto the same wall brackets.
