주요 콘텐츠로 건너뛰기
Toy Lightsaber Battery Replacement
필요한 것
  1. Toy Lightsaber Battery Replacement, Battery: 1 단계, 이미지 1/3 Toy Lightsaber Battery Replacement, Battery: 1 단계, 이미지 2/3 Toy Lightsaber Battery Replacement, Battery: 1 단계, 이미지 3/3
    • Remove the Lightsaber blade by carefully twisting it off the hilt.
    • Be gentle during this process to avoid damaging the blade or the hilt.
  2. Toy Lightsaber Battery Replacement: 2 단계, 이미지 1/3 Toy Lightsaber Battery Replacement: 2 단계, 이미지 2/3 Toy Lightsaber Battery Replacement: 2 단계, 이미지 3/3
    • Use a Phillips #2 screwdriver to remove the 3.5 mm screws on the hilt.
  3. Toy Lightsaber Battery Replacement: 3 단계, 이미지 1/3 Toy Lightsaber Battery Replacement: 3 단계, 이미지 2/3 Toy Lightsaber Battery Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the old C batteries.
    • If the batteries were leaking, be sure you thoroughly clean the inside of the hilt with a pair of tweezers to scrape off the battery acid and wipe away any acid that remains with a tissue or napkin.
    • Battery acid is toxic and dangerous for your health. Wear gloves to protect yourself.
  4. Toy Lightsaber Battery Replacement: 4 단계, 이미지 1/3 Toy Lightsaber Battery Replacement: 4 단계, 이미지 2/3 Toy Lightsaber Battery Replacement: 4 단계, 이미지 3/3
    • Place the new C batteries inside the newly cleaned hilt.
  5. Toy Lightsaber Battery Replacement: 5 단계, 이미지 1/3 Toy Lightsaber Battery Replacement: 5 단계, 이미지 2/3 Toy Lightsaber Battery Replacement: 5 단계, 이미지 3/3
    • Use your Philips #2 screwdriver to screw the 3.5 mm screws back into the hilt.
  6. Toy Lightsaber Battery Replacement: 6 단계, 이미지 1/3 Toy Lightsaber Battery Replacement: 6 단계, 이미지 2/3 Toy Lightsaber Battery Replacement: 6 단계, 이미지 3/3
    • Lastly, twist the Lightsaber blade back on top of the hilt.
    • Press the red button on the hilt to test if the blade glows.
    • If the blade doesn't glow, start over and try again with different C batteries.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Zachary Adaes
회원 가입일: 03/22/21
133 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G1, Saloman Spring 2021 UMass Dartmouth, Team S3-G1, Saloman Spring 2021 회원
UMASSD-SALOMAN-S21S3G1
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 84
전체 시간: 3,621
