주요 콘텐츠로 건너뛰기
Toy Windmill Repair
필요한 것
  1. Toy Windmill Repair, Toy Windmill Repair: 1 단계, 이미지 1/1
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: 2 단계, 이미지 1/1
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: 3 단계, 이미지 1/2 Toy Windmill Repair: 3 단계, 이미지 2/2
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: 4 단계, 이미지 1/1
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: 5 단계, 이미지 1/1
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: 6 단계, 이미지 1/2 Toy Windmill Repair: 6 단계, 이미지 2/2
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
결론
To reassemble your device, follow these instructions in order.
Karim Ladha
회원 가입일: 06/27/21
133 평판
안내서 1개 작성함
York University, Team S2-G15, Melo-Thaiss Summer 2021 York University, Team S2-G15, Melo-Thaiss Summer 2021 회원
YORK-MELO-THAISS-SU21S2G15
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 13
전체 시간: 320
