주요 콘텐츠로 건너뛰기
Toy Windmill Repair
필요한 것
  1. Toy Windmill Repair, Toy Windmill Repair: 1 단계, 이미지 1개 중 1개
    • Use the 120 grit sandpaper to remove any rough edges on both the base unit and any parts which need to be connected to it.
  2. Toy Windmill Repair: 2 단계, 이미지 1개 중 1개
    • Use the rough sandpaper on parts that need to be connected to the primary unit as this will result in greater surface contact.
  3. Toy Windmill Repair: 3 단계, 이미지 2개 중 1개 Toy Windmill Repair: 3 단계, 이미지 2개 중 2개
    • Apply a small amount of wood glue to each end.
    • Connect the two pieces and apply a small amount of masking tape to hold them in place.
  4. Toy Windmill Repair: 4 단계, 이미지 1개 중 1개
    • Once all the pieces have been connected and the glue has cured, use the fine sandpaper to smooth out the connected pieces.
  5. Toy Windmill Repair: 5 단계, 이미지 1개 중 1개
    • Using the fill stick crayon, blend in the connected pieces.
    • This will require the reader to be creative.
  6. Toy Windmill Repair: 6 단계, 이미지 2개 중 1개 Toy Windmill Repair: 6 단계, 이미지 2개 중 2개
    • Apply a small amount of wood glue to each end of the windmill.
    • Connect the two pieces and apply a small amount of masking tape to hold the two ends in place.
결론
To reassemble your device, follow these instructions in order.
작성자
2다른 기여자 명과 함께
Karim Ladha
회원 가입일: 06/27/21
133 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 16
전체 시간: 474
