주요 콘텐츠로 건너뛰기
Toyota Corolla 2018 Brake Light Replacement
필요한 것
  1. Toyota Corolla 2018 Brake Light Replacement, Brake Light: 1 단계, 이미지 1/2 Toyota Corolla 2018 Brake Light Replacement, Brake Light: 1 단계, 이미지 2/2
    • Open the trunk lid and remove the two black plastic fasteners on the side of the car with burnt out lights using a flat head screwdriver.
  2. Toyota Corolla 2018 Brake Light Replacement: 2 단계, 이미지 1/2 Toyota Corolla 2018 Brake Light Replacement: 2 단계, 이미지 2/2
    • Pull back the carpet to access the bulbs and locate between the rear turn signal bulb and brake light.
    • The rear turn signal bulb is located at the top and has a grey cap.
    • The brake light is located at the bottom and has an orange cap.
  3. Toyota Corolla 2018 Brake Light Replacement: 3 단계, 이미지 1/2 Toyota Corolla 2018 Brake Light Replacement: 3 단계, 이미지 2/2
    • Turn the brake light counterclockwise and pull the old light straight out of the socket.
  4. Toyota Corolla 2018 Brake Light Replacement: 4 단계, 이미지 1/1
    • Replace the new bulb and push it in the socket.
  5. Toyota Corolla 2018 Brake Light Replacement: 5 단계, 이미지 1/1
    • Turn the socket clockwise while placing it in the housing.
  6. Toyota Corolla 2018 Brake Light Replacement: 6 단계, 이미지 1/2 Toyota Corolla 2018 Brake Light Replacement: 6 단계, 이미지 2/2
    • Push the carpet back in place and screw in the two fasteners to secure the trunk liner.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Nishanth Selvarajah
회원 가입일: 07/07/20
187 평판
안내서 1개 작성함
York University, Team S1-G4, Allen Summer 2020 York University, Team S1-G4, Allen Summer 2020 회원
YORK-ALLEN-SU20S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 19
30일 전: 93
전체 시간: 3,717
