주요 콘텐츠로 건너뛰기
Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement
필요한 것
  1. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: 1 단계, 이미지 1/2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement, Tailgate Handle: 1 단계, 이미지 2/2
    • Remove the Torx-head screws (23.2mm) on the inside panel of the tailgate, using the torx T25 screwdriver.
  2. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 2 단계, 이미지 1/2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 2 단계, 이미지 2/2
    • Pull off the panel and then pull cables inward, causing tailgate to release and go down.
  3. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 3 단계, 이미지 1/2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 3 단계, 이미지 2/2
    • Remove rubber pieces from cable and pull cable from insert.
  4. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 4 단계, 이미지 1/2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 4 단계, 이미지 2/2
    • Use your 5/16th-in. wrench to turn bolt counter clockwise and remove the bolts (18.5mm).
  5. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 5 단계, 이미지 1/2 Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 5 단계, 이미지 2/2
    • Push in black clip to let handle fall out.
  6. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 6 단계, 이미지 1/1
    • Put new tailgate handle back in.
  7. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 7 단계, 이미지 1/1
    • Hand twist in bolts; then tighten with wrench.
  8. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 8 단계, 이미지 1/1
    • Insert cable back into socket and press rubber lock onto cable.
  9. Toyota Tundra 2nd generation (2007-2013) Tailgate Handle Replacement: 9 단계, 이미지 1/1
    • Put panel back into place and screw in using your torx -T25 screwdriver.
결론
This Device is a medium hardness fix but, with hard-work it can be achieved in only about 30 minutes
Brandon Gibson
회원 가입일: 03/26/20
169 평판
안내서 1개 작성함
댓글 2개
You skipped the problematic part about changing the lock.
Declan Haptism - 답글
I’m about to replace my handle.. I also need the 4 white clips that help align the latch rods. Mine were old brittle and all broken. Any chance you have a part number for those small clips?
Ryan Rodriguez - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 38
30일 전: 159
전체 시간: 10,182
