주요 콘텐츠로 건너뛰기
Track Cleats Spikes Replacement
필요한 것
  1. Track Cleats Spikes Replacement, Spikes: 1 단계, 이미지 1개 중 1개
    • Place a cleat wrench over the spike and rotate it clockwise until it locks in place.
  2. Track Cleats Spikes Replacement: 2 단계, 이미지 1개 중 1개
    • Rotate the wrench counterclockwise 4 to 5 times, or until the spike detaches from the sole.
  3. Track Cleats Spikes Replacement: 3 단계, 이미지 1개 중 1개
    • Repeat Steps 1-2 to remove the remaining spikes.
  4. Track Cleats Spikes Replacement: 4 단계, 이미지 1개 중 1개
    • Clean the sole and screw holes using dish soap, a sponge or cloth, and warm water.
  5. Track Cleats Spikes Replacement: 5 단계, 이미지 1개 중 1개
    • Dry the shoe with a towel, and allow the sockets time to fully dry before installing new spikes.
    • Do not screw spikes into wet or damp sockets as the spikes will likely rust, making them extremely difficult, if not impossible, to remove in the future.
  6. Track Cleats Spikes Replacement: 6 단계, 이미지 1개 중 1개
    • Grab the new spike and place the thread into the screw hole. Screw the spikes clockwise back in place.
    • Screw the spikes until tight, then rotate another 1/16 of an inch. Be sure not to over-tighten the spikes.
  7. Track Cleats Spikes Replacement: 7 단계, 이미지 1개 중 1개
    • Repeat Step 6 for the remaining spikes.
  8. Track Cleats Spikes Replacement: 8 단계, 이미지 1개 중 1개
    • Make sure all the spikes are tight, and then proceed to test out shoes on an appropriate surface.
    • Always test new spikes before racing.
결론
Have fun running!
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Gabriel Williams
회원 가입일: 02/28/22
157 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 44
전체 시간: 1,225
