소개
In the event that a Traxxxas Summit begins to steer erratically, the user may need to replace one, or both, of the servos which power the device's steering assembly. This process is relatively quick, and does not require any special tools outside of a standard set of hex keys. This guide will detail the process step-by-step, teaching the user how to remove the old servo and replace it with a new one, which is readily available online.
필요한 것
Remove each of the four pins that hold the shell by pulling them from the posts.
다른 한 분이 해당 안내서를 완성하였습니다.
